Dell Inspiron 1546 Display Assembly Replacement
  1. Dell Inspiron 1546 Display Assembly Replacement, Remove the Cables: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Make note of the Mini-Card antenna cables routing and remove the cables from the routing guides.
  2. Dell Inspiron 1546 Display Assembly Replacement, Remove the Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws from the computer base.
  3. Dell Inspiron 1546 Display Assembly Replacement, Dislodge the Cables: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make note of the Mini-Card antenna cable routing and carefully dislodge the antenna cables from the cable routing slot on the computer. Pull the cables away, so that they are clear of the palm rest.
  4. Dell Inspiron 1546 Display Assembly Replacement, Disconnect the Cable: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the display cable and camera cable from the respective system board connectors and remove them from their routing guides.
  5. Dell Inspiron 1546 Display Assembly Replacement, Remove the Screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws that secure the display assembly to the computer base.
  6. Dell Inspiron 1546 Display Assembly Replacement, Remove the Display Assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the display assembly from the computer base.
  7. Dell Inspiron 1546 Display Assembly Replacement, Place the Display Assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the display assembly in position and replace the four screws that secure the display assembly to the computer base.
  8. Dell Inspiron 1546 Display Assembly Replacement, Route the Display Cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Route the display cable and camera cable into their routing guides and connect the cables to the respective system board connectors.
  9. Dell Inspiron 1546 Display Assembly Replacement, Route the Antenna Cables: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Route the Mini-Card antenna cables, and guide the cables to the bottom of the computer through the cable routing slot.
  10. Dell Inspiron 1546 Display Assembly Replacement, Replace the Screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the two screws at the bottom of the computer.
Terrence15
crwdns2935283:012/18/17crwdne2935283:0
79 831 crwdns2915208:0crwdne2915208:0
crwdns2935297:0441crwdne2935297:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01 991crwdne2935297:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 204
