This guide will be utilized if you are having issues with reading disks and it is not a firmware problem.
Turn the laptop over to its back.
Slide the release latch while simultaneously pulling backwards on the battery.
Slide the battery out of the battery bay.
Flip the laptop to its back side.
Remove the screw (5mm Phillips #1) that secures the Optical Disk Drive on the back of the laptop.
Push the Optical Disk Drive out using a spudger tool as shown and pull from the front cover of the Optical Disk Drive.
