Dell Inspiron 1545 Keyboard Replacement
  1. Dell Inspiron 1545 Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 Keyboard Replacement, Base Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1545 Keyboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 Keyboard Replacement, Center Control Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
  7. Dell Inspiron 1545 Keyboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over to the front and open the display as far as possible.
  8. Dell Inspiron 1545 Keyboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1545 Keyboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1545 Keyboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The Center Control Cover is VERY fragile, be careful when using prying tools.
    • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
    • Carefully lift the Center Control Cover away from the laptop.
  9. Dell Inspiron 1545 Keyboard Replacement, Keyboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
  10. Dell Inspiron 1545 Keyboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
    • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
  11. Dell Inspiron 1545 Keyboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
    The connector latch is the black piece.
    Maurice Volaski - crwdns2934203:0crwdne2934203:0
    Good tip! As shown. flips up and toward user
    Tom Borden - crwdns2934203:0crwdne2934203:0
  12. Dell Inspiron 1545 Keyboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the keyboard up and away from the laptop.
crwdns2935229:015crwdne2935229:0
Nathan Lemay
crwdns2935283:004/16/14crwdne2935283:0
3.112 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-14, Regan Spring 2014 crwdns2935289:0Cal Poly, Team 9-14, Regan Spring 2014crwdne2935289:0
CPSU-REGAN-S14S9G14
Steps 4 and 5 are unnecessary for removing the keyboard. Other than that, well done.
lee - crwdns2934203:0crwdne2934203:0
The connector latch is broken. What should I do?
Mjeed - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 7,275
