Dell Inspiron 1526 Webcam Replacement
  1. Dell Inspiron 1526 Webcam Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1526 Webcam Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1526 Webcam Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the unlock button to the left to release the battery.
    • Slide the battery away from the laptop to remove.
    • The unlock button is located on the bottom of the laptop.
  2. Dell Inspiron 1526 Webcam Replacement, Keyboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the two 3.5mm Phillips #1 screws in the battery bay.
  3. Dell Inspiron 1526 Webcam Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over.
    • Lift the control cover by prying the right side of the cover with an iFixit opening tool.
  4. Dell Inspiron 1526 Webcam Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the control cover up and forward to reveal a single ribbon cable.
  5. Dell Inspiron 1526 Webcam Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to squeeze the tabs on the connector and remove the ribbon cable.
  6. Dell Inspiron 1526 Webcam Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1526 Webcam Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the control cover.
  7. Dell Inspiron 1526 Webcam Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3mm Phillips #1 screws at the top of the keyboard where the control cover was.
  8. Dell Inspiron 1526 Webcam Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the keyboard gently from the top, but do not remove completely.
    • Looking under the keyboard, towards the touch-pad in the center, lift up the black tab on the connector with tweezers for the keyboard ribbon cable.
  9. Dell Inspiron 1526 Webcam Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1526 Webcam Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the keyboard.
  10. Dell Inspiron 1526 Webcam Replacement, Screen: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1526 Webcam Replacement, Screen: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six plastic pads around the bezel using an iFixit opening pick.
    • Remove the six 3mm Phillips #0 screws under each pad.
  11. Dell Inspiron 1526 Webcam Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1526 Webcam Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1526 Webcam Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the computer so that it rests flat on the table.
    • Separate the bezel from the black plastic frame using a spudger.
    • There are a dozen snaps around the perimeter of the bezel and there are two between the pivot joints of the laptop.
  12. Dell Inspiron 1526 Webcam Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1526 Webcam Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3mm Phillips #1 screws at the bottom of the display panel.
    • Lift the display slightly from the top, then pull outwards.
    • Flip the display panel around to the back.
    • Disconnect the connector and remove the ribbon cable.
  13. Dell Inspiron 1526 Webcam Replacement, Webcam: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1526 Webcam Replacement, Webcam: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the webcam connector.
  14. Dell Inspiron 1526 Webcam Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From both sides, pry and pull upwards from the back of the display cover.
    • This module has no screws affixing it to the display cover; it is held in by snapping it into the plastic brackets.
Ahmed Alshamsi
crwdns2935283:009/17/19crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S20-G3, Branham Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S20-G3, Branham Fall 2019crwdne2935289:0
ERAU-BRANHAM-F19S20G3
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 221
