Dell Inspiron 1525 Display Assembly Replacement
    1. Dell Inspiron 1525 Display Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the battery release switch on the bottom of the laptop.
    2. Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the battery release switch away from the lock symbol until you hear the battery click.
      • Slide the battery towards the back of the laptop until it comes free.
    1. Dell Inspiron 1525 Display Assembly Replacement, Central Control Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
    2. Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
      • Carefully pull the central control cover up along its edges.
      • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
    3. Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Peel back the silver tape securing the ribbon cable to the cover.
      • Pull the small brown latch on the ribbon cable connector out.
      • Disconnect the ribbon cable to completely free the central control cover.
    1. Dell Inspiron 1525 Display Assembly Replacement, Keyboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1525 Display Assembly Replacement, Keyboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
      • Gently slide the keyboard towards the display until the tabs on its front side are free.
      • Do not force the keyboard too far forward or attempt to remove it yet, as there is still a ribbon cable connected to it.
    2. Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to gently lift the ribbon cable retaining flap.
      • Disconnect the ribbon cable.
      • Shift the keyboard sideways enough to free one side from it's retaining tab. Then lift the keyboard away from the laptop.
    1. Dell Inspiron 1525 Display Assembly Replacement, Bottom Cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1525 Display Assembly Replacement, Bottom Cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
      • The screws may only need to be loosened, as they are generally retained by plastic washers.
      • Remove the bottom panel.
    1. Dell Inspiron 1525 Display Assembly Replacement, Display Assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1525 Display Assembly Replacement, Display Assembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1525 Display Assembly Replacement, Display Assembly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Disconnect the five antennas from their respective cards.
      • De-route the antennas from their routing retainers.
    2. Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 5.70 mm Phillips #1 screws securing the display assembly to the bottom case half.
      • The screw holes will be denoted by an embossed "D" by the hole.
    3. Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the flat end of a spudger to push the camera connector out of its socket. Alternate pushing on either side to evenly remove the connector.
      • Carefully release the connector from its retaining tabs.
    4. Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Push the antenna wires up through their hole in the bottom case half.
      • Release the antennas from their retaining tabs on the upper case.
    5. Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect the flat LCD ribbon cable by pulling it up by the tab.
      • Free the ribbon cable from its retaining clips.
    6. Dell Inspiron 1525 Display Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 3.45 mm Phillips #1 screws securing the display assembly to the laptop chassis.
      • Support the display assembly as you remove these screws to prevent damage to the screw and hole threads.
      • Remove the display assembly from the laptop.
crwdns2935229:08crwdne2935229:0
Hi There,
Thanks for the great article. Can you please advise what is the part number (LCD number). For example I have LTN156AT17-101 for my Inspiron N5110. I am actually planning to use the screen from 1525 to replace the one in N5110. Are they both same connector type? Thanks.
Zaheer Meerja - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 10,408
