Dell Inspiron 1520 Memory Modules Replacement
  1. Dell Inspiron 1520 Memory Modules Replacement, Lifting the Memory Module: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Follow the procedures in Before You Begin.
    • Lift the memory module cover but do not remove it.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
  2. Dell Inspiron 1520 Memory Modules Replacement, Popping up the Memory Module: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  3. Dell Inspiron 1520 Memory Modules Replacement, Remove the Module: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the module from the connector.
  4. Dell Inspiron 1520 Memory Modules Replacement, DIMM B Memory Module: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the computer over.
    • Loosen the captive screw on the memory module cover, then remove the cover and set it aside.
  5. Dell Inspiron 1520 Memory Modules Replacement, Popping up the Memory Module: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1520 Memory Modules Replacement, Popping up the Memory Module: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  6. Dell Inspiron 1520 Memory Modules Replacement, Remove the Memory Module: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the memory module from the connector.
  7. Dell Inspiron 1520 Memory Modules Replacement, Replacing the DIMM A Memory Module: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1520 Memory Modules Replacement, Replacing the DIMM A Memory Module: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align the notch in the NEW memory module edge connector with the tab in the connector slot.
  8. Dell Inspiron 1520 Memory Modules Replacement, Sliding the Memory Module: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the memory module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot. No error message indicates this failure.
  9. Dell Inspiron 1520 Memory Modules Replacement, Replace the Memory Module Cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the memory module cover.
  10. Dell Inspiron 1520 Memory Modules Replacement, Replacing DIMM B Memory Module: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  11. Dell Inspiron 1520 Memory Modules Replacement, Align the Notch: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1520 Memory Modules Replacement, Align the Notch: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align the notch in the module edge connector with the tab in the connector slot.
  12. Dell Inspiron 1520 Memory Modules Replacement, Sliding the Module: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
  13. Dell Inspiron 1520 Memory Modules Replacement, Replace the Module Cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • NOTICE: If the cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
    • Replace the memory module cover and tighten the screw.
Terrence15
crwdns2935283:012/18/17crwdne2935283:0
79 585 crwdns2915208:0crwdne2915208:0
crwdns2935297:0441crwdne2935297:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01 985crwdne2935297:0
crwdns2942667:0crwdne2942667:0 317
