The guide shows the process of removing the RAM from the Dell Insprion 15-7547.
Close the display and flip the laptop on its back.
Loosen the ten 5.0 mm-long Phillips #0 screws.
The four screws marked with orange will remain captive to the cover.
Use a spudger to pry up and loosen the back cover.
Remove the back cover.
Remove the plastic heat spreader that covers the RAM sticks.
Release the clamps on each side of the RAM sticks by pushing away from the center.
Pull the RAM stick in a straight line out of the socket.
