This guide shows how to remove the LCD assembly from a Dell Inspiron 15-7547
Close the display and flip the laptop on its back.
Loosen the ten 5.0 mm-long Phillips #0 screws.
The four screws marked with orange will remain captive to the cover.
Use a spudger to pry up and loosen the back cover.
Remove the back cover.
Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card
Remove the Wifi-Card from its socket by pulling away and up from the connector.
Disconnect the white and black cables from the Wifi-Card.
Remove the six 7.0 mm-long Philips #0 screws that mount the hinges.
Use a spudger to unlatch and unplug the display cable.
Remove the LCD display assembly from the laptop.
