Dell Inspiron 15-5567 CPU Fan Replacement
  1. Dell Inspiron 15-5567 CPU Fan Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15-5567 CPU Fan Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15-5567 CPU Fan Replacement, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
    • Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
    • Remove two M2x4mm screws using the same screwdriver.
  2. Dell Inspiron 15-5567 CPU Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-5567 CPU Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the blue plastic opening tool into the crease of the CD driver, and pop it open.
    • Slide the rest of it out with your hand.
  3. Dell Inspiron 15-5567 CPU Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15-5567 CPU Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15-5567 CPU Fan Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove three M2x2mm screws underneath the CD driver with the same Philips #0 screwdriver.
    • Place the blue plastic opening tool in the crease of the cover and push it upward to open the back cover.
    • Grab the corners of the cover firmly and lift it up.
    • Some parts are weaker than others; open it gently from corners.
  4. Dell Inspiron 15-5567 CPU Fan Replacement, CPU Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15-5567 CPU Fan Replacement, CPU Fan: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15-5567 CPU Fan Replacement, CPU Fan: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four M2.5x5mm screws from the fan using a Philips #0 screwdriver.
    • The four screws over the processor will not come off all the way, they'll just loosen up.
    • Remove the other four M2x3mm screws using a Philips #0 screwdriver.
    • Gently disconnect the fan cable from the motherboard using the blue plastic opening tool.
  5. Dell Inspiron 15-5567 CPU Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the fan and its components up and remove it.
Sattam Bakolka
crwdns2935283:001/14/20crwdne2935283:0
732 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S16-G1, Branham Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S16-G1, Branham Spring 2020crwdne2935289:0
ERAU-BRANHAM-S20S16G1
Warning, under the fan, a thin cable going to the CD drive was stuck with tape. I was able to remove it, but the connector did pull out of the motherboard, which took a bit of fiddling to get connected again.
Craig Treptow - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 5,845
