Dell Inspiron 15-5552 Memory Replacement
  1. Dell Inspiron 15-5552 Memory Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Memory Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Memory Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Memory Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-5552 Memory Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 Memory Replacement, Screw Location: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device on its back, locate the screws circled.
  6. Dell Inspiron 15-5552 Memory Replacement, Screw Removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a J0 screwdriver to unscrew the two, 6mm Phillips screw on the rear-cover.
  7. Dell Inspiron 15-5552 Memory Replacement, Removing Cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15-5552 Memory Replacement, Removing Cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15-5552 Memory Replacement, Removing Cover: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, Lightly lift the rear-cover up and at an angle, away from the computer.
  8. Dell Inspiron 15-5552 Memory Replacement, RAM Removal: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-5552 Memory Replacement, RAM Removal: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  9. Dell Inspiron 15-5552 Memory Replacement, RAM Removal Contiuned: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-5552 Memory Replacement, RAM Removal Contiuned: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the dislodged up RAM by pulling it away from the connection.
    • If it does not pop up, pry it out in a steady and straight direction.
Chandler Champion
crwdns2935283:001/23/18crwdne2935283:0
364 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team S1-G4, Virtue Spring 2018 crwdns2935289:0Western Carolina University, Team S1-G4, Virtue Spring 2018crwdne2935289:0
WCU-VIRTUE-S18S1G4
crwdns2942667:0crwdne2942667:0 375
