Dell Inspiron 15-3543 Touchpad Replacement
  1. Dell Inspiron 15-3543 Touchpad Replacement, Touchpad: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement, Touchpad: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device over so the bottom is facing up.
    • Using a #0 Phillips screwdriver, remove the 4.0mm screw to the right of the disk drive.
  2. Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the disk drive out and sit it to the side.
  3. Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a #0 Phillips screwdriver, remove the 2.0mm screw from the back of the device beside the vents.
  4. Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the panel off by placing your hands on top and, while using a little force, sliding your hands down.
  5. Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a #0 Phillips screwdriver, remove the 2.0mm screw beside the black pull tab on the hard drive to the bottom left of the device.
  6. Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the black tab up and to the left to completely remove the hard drive.
    • Sit the hard drive to the side once it is out.
  7. Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the device over and open it.
    • You will see 5 notches at the top of the keyboard.
    • Stick the end of the metal spudger between each of these notches to pry the keyboard up. Once you hear a pop sound, stop and move onto the next notch.
  8. Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once all five notches at the top of the keyboard are loosened, begin pulling it up from the top.
    • Pull the keyboard up slowly so you don't tear the ribbon cable out or damage it.
  9. Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the ribbon cable, use the metal spudger tool to pop the ribbon cable lock up.
    • After popping up the ribbon cable lock, you can pull the ribbon cable out and sit the keyboard to the side.
  10. Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the two battery locks outwards.
  11. Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the top of the battery up and out.
    • Sit the bettery to the side once it is out.
  12. Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the following ten screws with a #0 Phillips screwdriver:
    • Two 8.0mm screws.
    • Eight 4.0mm screws.
  13. Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a #0 Phillips screwdriver, remove the three 4.0mm screws on the front where the keyboard used to be.
  14. Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the front of the device, there will be two ribbon cables. Remove them using the following directions:
    • Pull the black cable ribbon lock up and pull the blue ribbon out using the tab.
    • Pull the white cable ribbon lock up and pull the blue ribbon out using the tab .
  15. Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the one or two opening tools, pry the bottom of the top plate off starting underneath the headphone jack.
  16. Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue going around the device and prying it open until the top panel is off.
  17. Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the inside of the top panel, pull the black ribbon cable lock up and pull the ribbon cable out using the tab.
  18. Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a #0 Phillips screwdriver, remove the three 1.0mm screws.
  19. Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-3543 Touchpad Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the metal plate up and out from the top.
Brianna Blackburn
crwdns2935283:001/23/18crwdne2935283:0
954 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team S1-G6, Virtue Spring 2018 crwdns2935289:0Western Carolina University, Team S1-G6, Virtue Spring 2018crwdne2935289:0
WCU-VIRTUE-S18S1G6
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 1,357
