Dell Inspiron 15 Optical Drive Replacement
  1. Dell Inspiron 15 Optical Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15 Optical Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 Optical Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 Optical Drive Replacement, Optical Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15 Optical Drive Replacement, Optical Drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 5mm long Phillips #0 screw that is holding the optical drive in place, as pictured.
    • You can now slide the optical disk drive out of the computer.
    • You do not have to remove the base cover or the Hard Drive if you want to remove just the optical drive.
Edward Pacheco
crwdns2935283:003/06/16crwdne2935283:0
848 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-8, Landers Spring 2016 crwdns2935289:0UMass Dartmouth, Team 5-8, Landers Spring 2016crwdne2935289:0
UMASSD-LANDERS-S16S5G8
crwdns2942667:0crwdne2942667:0 4,921
