In this guide, we will be showing you how to remove and replace the Display Assembly.
Remove the screws that secure the display hinges to the palm-rest assembly and open the hinges to an angle of 90 degrees.
Note the antenna cable routing and remove the cable from its routing guides on the palm-rest assembly.
Note the display cable routing and remove the cable from its routing guides on the palm-rest assembly.
Open the palm-rest assembly.
Lift the palm-rest assembly at an angle off the display assembly.
Place the display assembly on a clean, flat surface.
Place the NEW display assembly on the palm-rest assembly.
Close the display hinges and align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
Replace the screws that secure the display hinges to the palm-rest assembly.
Route the display cable through its routing guides on the palm-rest assembly.
Route the antenna cables through its routing guides on the palm-rest assembly.
Close the display and turn the computer over.
I can't replace the cables on the left side of the lid through the hinge.
