Dell Inspiron 15 7579 Speakers Replacement
  1. Dell Inspiron 15 7579 Speakers Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15 7579 Speakers Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Speakers Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15 7579 Speakers Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 7.8 mm long screws on the left side of the battery with the Phillips #1 screwdriver.
  4. Dell Inspiron 15 7579 Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the fabric clip that attaches the battery to the main board from the connector by hand.
    • Remove the battery from the device.
  5. Dell Inspiron 15 7579 Speakers Replacement, Speakers: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15 7579 Speakers Replacement, Speakers: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After battery is removed, locate the left and right speakers.
    • On the right speaker assembly, remove the pin connector using the tweezers.
  6. Dell Inspiron 15 7579 Speakers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15 7579 Speakers Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the metal spudger to pry off the right speaker assembly.
  7. Dell Inspiron 15 7579 Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a metal spudger to pry off left speaker assembly.
  8. Dell Inspiron 15 7579 Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15 7579 Speakers Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Un-thread the wire by removing them from under the plastic clamps. No tools are required for this step. Repeat for both sides.
  9. Dell Inspiron 15 7579 Speakers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15 7579 Speakers Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the adhesive cable away from the metal backing and push the right speaker assembly under it.
    • Remove the Velcro holding the speaker wire and remove the speakers from the device.
Inaki Madrigal
crwdns2935283:004/23/18crwdne2935283:0
775 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S24-G9, Maness Spring 2018 crwdns2935289:0Cal Poly, Team S24-G9, Maness Spring 2018crwdne2935289:0
CPSU-MANESS-S18S24G9
crwdns2942667:0crwdne2942667:0 1,325
