Dell Inspiron 15 7579 RAM (Memory) Replacement
  1. Dell Inspiron 15 7579 RAM (Memory) Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 RAM (Memory) Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15 7579 RAM (Memory) Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 RAM (Memory) Replacement, RAM (Memory): crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fold protective flaps to the side on the RAM module located in the upper right corner of the laptop.
  4. Dell Inspiron 15 7579 RAM (Memory) Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15 7579 RAM (Memory) Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15 7579 RAM (Memory) Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tweezers to push the crimping metal away from the chip. The chip will pop up into an angled position.
    • Remove the chip by pulling at the same angle as the chip with the tweezers.
  5. Dell Inspiron 15 7579 RAM (Memory) Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15 7579 RAM (Memory) Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15 7579 RAM (Memory) Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Fold the plastic flap over on the other side.
    • As before, pull the fasteners away from the chip with the tweezers.
    • Remove the chip by carefully pulling it out with the tweezers.
  6. Dell Inspiron 15 7579 RAM (Memory) Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15 7579 RAM (Memory) Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When reassembling, you must match the notch in the card with the notch in the connector header shown in red.
    • Doing otherwise will break the stick if forced.
Inaki Madrigal
crwdns2935283:004/23/18crwdne2935283:0
775 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S24-G9, Maness Spring 2018 crwdns2935289:0Cal Poly, Team S24-G9, Maness Spring 2018crwdne2935289:0
CPSU-MANESS-S18S24G9
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 789
