If your Dell Inspiron 15 7579 is having issues with the display such as flickering, monitor ghosting, or any other issue concerning the display of the laptop, this guide will walk you through step by step to help fix your laptop. This guide will require you to remove other parts of the laptop before you can remove the display.
Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
Insert metal spudger into a gap in between the back panel and the back of the screen.
Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
Remove the two 7.9 mm screws from the fan with a Phillips #0 screwdriver.
Carefully lift the fan out of the computer.
Remove the single 3.6 mm screw holding the left side of the M.2 SSD card with a Phillips PH0 screwdriver.
Gently pull out the SSD card at the angle it is relaxed in to remove it. It is easiest to do this by hand.
Remove the six 2.1 mm screws with the Phillips #0 screwdriver.
Unplug the eight ribbon cables connected to the motherboard.
Lift the motherboard up from the side opposite of the external ports and remove it from the laptop.
Remove the screw that holds the Wi-Fi card in place with a Phillips #0 screwdriver.
Disconnect the black and white coaxial cables from the Wi-Fi card.
Remove the Wi-Fi card from its port.
Remove the two screws from the metal plates with the Phillips #0 screwdriver.
Lift up the two hinges perpendicularly to the board beneath it.
Lift up on the keyboard at an angle from the laptop and gently pull away from hinges.
