This guide will lead you through the process of removing the back panel of the Dell Inspiron 15 7579 to access the internal components.
Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
Insert metal spudger into a gap in between the back panel and the back of the screen.
Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
