When your Dell laptop starts overheating or making strange fan noises, it may be time to consider a fan replacement. This replacement will improve heating issues, and protect your laptop from potential harm. Basic hardware skills are a must, along with having a gentle touch to navigate the disassembly process. Successfully swapping out the fan requires careful precision, making this repair a rewarding yet complex task for your Dell Inspiron 15 5577.
Unscrew the base cover plate to locate the gaming fan.
Gently tug on the battery cable in order to disconnect it from the motherboard.
Loosen the screws that secure the battery in place.
Carefully pull the battery out of the laptop.
Remove the cable above the hard drive.
Loosen the screws that secure the hard drive.
Flip the laptop over and open the lid.
Remove the palm rest.
Carefully unsecure the rest of the shell on the base of the computer.
Loosen the screws securing the metal plate and contents of the base.
Unscrew and remove the first fan from the base of the laptop.
Remove the fan's cable from the board.
Repeat steps 14 and 15 for the remaining fan.
