In this guide, we will be showing you how to remove and replace the Memory Modules.
Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
Remove the memory module from the memory-module slot.
Align the notch on the NEW memory module with the tab on the memory-module slot.
Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
