The fan in this laptop prevents the computer from overheating. It provides good airflow into the computer and out through the vents. Any clogging or damage could cause other problems in your computer.
Close the display and turn over the computer.
Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
Lightly lift the RAM cover up and at an angle, away from the computer.
Use your fingers to carefully pull the securing clips on the RAM away from each other.
Remove the popped up RAM by pulling it away from the connection.
Slide the CD/DVD drive on the side of the laptop out using your fingers.
Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
Lift the plastic yellow flap on the system board.
Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
Flip over the computer and open the display.
Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
Lift the keyboard off of the computer.
Flip the keyboard over onto the palm-rest assembly.
Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove all 7 rubber screw caps with tweezers.
Use a J0 Bit tipped screwdriver unscrew the seven 6 mm Phillips screws on the back casing of the laptop.
Flip the computer over and open the display.
Pull on the blue tabs to disconnect the palm rest assembly from the computer.
Use J0 Bit screwdriver to remove all four 6 mm Phillips screws.
Gently wedge the nylon spudger underneath the palm-rest assembly to release the latches.
Continue this process on all sides of the computer edges until the assembly pulls off.
Remove the palm rest assembly.
Use a J0 Bit screwdriver to remove the two 6 mm Phillips screws securing the battery located near the bottom of the laptop.
Lift the tiny black tab and pull the battery out at a slight angle.
Lift up the bottom of the hard drive which is located at the bottom of the laptop.
Gently pull the drive out at an angle using your fingers.
Using a J0 bit tipped screwdriver, remove the four 3 mm black screws on both sides of the hard drive bracket.
Slide the hard drive out of the bracket.
Locate the wireless mini card at the top of the laptop.
Using a J0 tipped screwdriver, remove the 4 mm Phillips head screw.
Gently, unlatch the black and white wires from the wireless mini card.
At an angle, slide out the wireless mini card.
Gently pull the the blue ribbon upwards to disconnect the computer from the motherboard.
Using a plastic opening tool, gently detach the coin cell battery from the foam glue.
Using a J0 tipped screwdriver remove the 6 mm Phillips head screw located at the center of the laptop on the motherboard.
Remove motherboard at an upward angle.
Flip the motherboard over.
Locate the red and yellow wires attached to the fan and gently detach them from the motherboard.
Using a J0 tipped screwdriver remove the three 5 mm Phillips head screws that attach fan to the motherboard.
Remove the fan from the motherboard by lifting upwards.
Hurrah, just used these instructions to replace my fan and have a beautifully silent working laptop again - thanks! I skipped steps 20-23, and it would have been useful to have a mention that thermal compound was necessary to make a good connection when replacing the heat sink - but all in all great clear instructions. One happy good-as-new laptop owner!
This guide was bloody marvellous! This was the first time I’ve opened a laptop by myself and it was quite a ride but a fun one the only struggle that I had was the bloody blue ribbon connecting to the motherboard other than that the rest was really easy to follow. Thank you so much for the guide and I hope I can some day be a contributor just as great as you random internet person ^^
