The daughterboard is an extension of the motherboard. Follow this simple step by step replacment guide.
Close the display and turn over the computer.
Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
Lightly lift the RAM cover up and at an angle, away from the computer.
Use your fingers to carefully pull the securing clips on the RAM away from each other.
Remove the popped up RAM by pulling it away from the connection.
Slide the CD/DVD drive on the side of the laptop out using your fingers.
Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
Lift the plastic yellow flap on the system board.
Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
Flip over the computer and open the display.
Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
Lift the keyboard off of the computer.
Flip the keyboard over onto the palm-rest assembly.
Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove all 7 rubber screw caps with tweezers.
Use a J0 Bit tipped screwdriver unscrew the seven 6 mm Phillips screws on the back casing of the laptop.
Flip the computer over and open the display.
Pull on the blue tabs to disconnect the palm rest assembly from the computer.
Use J0 Bit screwdriver to remove all four 6 mm Phillips screws.
Gently wedge the nylon spudger underneath the palm-rest assembly to release the latches.
Continue this process on all sides of the computer edges until the assembly pulls off.
Remove the palm rest assembly.
Use a J0 Bit screwdriver to remove the two 6 mm Phillips screws securing the battery located near the bottom of the laptop.
Lift the tiny black tab and pull the battery out at a slight angle.
Locate the black cord that was underneath the battery.
Carefully lift up the chip connected to the end of the cord on the daughter board.
Use a J0 Bit screwdriver to remove the two 6 mm Phillips head screw located on the daughter board.
Pick the daughter board up and flip it over.
Disconnect the black cable from the white connector by pulling the speaker cord from the daughter board.
