Dell Inspiron 14z-5423 Battery Replacement
  1. Dell Inspiron 14z-5423 Battery Replacement, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement, RAM: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Battery Replacement, Optical Drive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement, Optical Drive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the CD/DVD drive on the side of the laptop out using your fingers.
    • Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
    • You only need to unscrew this screw if you are using this as a prerequisite guide.
  7. Dell Inspiron 14z-5423 Battery Replacement, Keyboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement, Keyboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement, Keyboard: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the plastic yellow flap on the system board.
    • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
  8. Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip over the computer and open the display.
  9. Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
    • Lift the keyboard off of the computer.
    • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
  10. Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the keyboard over onto the palm-rest assembly.
  11. Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
  12. Dell Inspiron 14z-5423 Battery Replacement, Palm Rest Assembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  13. Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all 7 rubber screw caps with tweezers.
    • Use a J0 Bit tipped screwdriver unscrew the seven 6 mm Phillips screws on the back casing of the laptop.
  14. Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the computer over and open the display.
    • Pull on the blue tabs to disconnect the palm rest assembly from the computer.
  15. Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use J0 Bit screwdriver to remove all four 6 mm Phillips screws.
  16. Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently wedge the nylon spudger underneath the palm-rest assembly to release the latches.
    • Continue this process on all sides of the computer edges until the assembly pulls off.
    • Remove the palm rest assembly.
    • If you have difficulty lifting up the assembly, you might not have taken out all 7 screws on the bottom of the computer.
  17. Dell Inspiron 14z-5423 Battery Replacement, Battery: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement, Battery: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a J0 Bit screwdriver to remove the two 6 mm Phillips screws securing the battery located near the bottom of the laptop.
  18. Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 14z-5423 Battery Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the tiny black tab and pull the battery out at a slight angle.
Brittany
crwdns2935283:009/12/16crwdne2935283:0
917 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 2-2, Bruce Fall 2016 crwdns2935289:0CSU Fullerton, Team 2-2, Bruce Fall 2016crwdne2935289:0
CSUF-BRUCE-F16S2G2
crwdns2935297:011crwdne2935297:0
Thanks! These instructions worked very well for me, and I performed my battery and disk upgrades successfully!
ericfogleman - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,804
