In this guide, we will be showing you how to remove and replace the Display Assembly.
Remove the two screws on the base of the computer that secure the display assembly to the computer base.
Disconnect the display cable and remove the screw from the system board.
Pull the Mini-Card antenna cables up through the slot in the computer base.
Note the routing of all the cables and remove them from their routing guides.
Hold the display while you remove the three screws that secure the display assembly to the computer base.
Lift and remove the display assembly from the computer base.
Using the alignment posts, place the NEW display assembly in position and replace the three screws that secure the display assembly to the computer base.
Route the Mini-Card antenna cables and display cable through their routing guides.
Route the antenna cables through the slot in the computer base.
Replace the screw and connect the display cable.
