Dell Inspiron 1464 Display Assembly Replacement
  1. Dell Inspiron 1464 Display Assembly Replacement, Note the Routing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
    • Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the bottom of the computer.
  2. Dell Inspiron 1464 Display Assembly Replacement, Remove the Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws on the bottom of the computer that secure the display assembly to the computer base.
  3. Dell Inspiron 1464 Display Assembly Replacement, Pull the Cables Up: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the Mini-Card antenna cables up through the slot in the computer base.
  4. Dell Inspiron 1464 Display Assembly Replacement, Note the Routing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the palm rest.
  5. Dell Inspiron 1464 Display Assembly Replacement, Disconnect the Display Cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the display cable from the connector on the system board and remove the display cable grounding screw.
  6. Dell Inspiron 1464 Display Assembly Replacement, Remove the Screws: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three screws that secure the display assembly to the computer base.
  7. Dell Inspiron 1464 Display Assembly Replacement, Removing the Display Assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the display assembly off the alignment posts on the computer base.
  8. Dell Inspiron 1464 Display Assembly Replacement, Placing the Display Assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the alignment posts to place the NEW display assembly on the computer base.
  9. Dell Inspiron 1464 Display Assembly Replacement, Replace the Screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the three screws that secure the display assembly to the computer base.
  10. Dell Inspiron 1464 Display Assembly Replacement, Connecting the Display Cable: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect the display cable to the connector on the system board and replace the display cable grounding screw.
  11. Dell Inspiron 1464 Display Assembly Replacement, Routing the Cables: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Route the Mini-Card antenna cables through the routing guides on the palm rest.
  12. Dell Inspiron 1464 Display Assembly Replacement, Thread the Cables: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Thread the Mini-Card antenna cables through the slot in the computer base.
  13. Dell Inspiron 1464 Display Assembly Replacement, Replace the Screws: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the computer over and replace the two screws that secure the display assembly to the computer base.
Terrence15
crwdns2935283:012/18/17crwdne2935283:0
79,825 crwdns2915208:0crwdne2915208:0
crwdns2935297:0441crwdne2935297:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01,991crwdne2935297:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 391
