Dell Inspiron 1420 Display Replacement
  1. Dell Inspiron 1420 Display Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1420 Display Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1420 Display Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the two tabs to release the battery.
    • Pull the battery out.
  2. Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry the 6 rubber bumpers from the display.
    • Using a Phillips #00 screwdriver, remove the six 4mm screws that are beneath the six rubber bumpers.
  3. Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pry the frame using a spudger.
    • Using a Phillips #00 screwdriver, remove the two 5mm screws at the bottom of the screen.
  4. Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to loosen the frame from the top.
    • Lift up the black connector to detach the gold ribbon.
  5. Dell Inspiron 1420 Display Replacement, Removing the Power Connector Cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1420 Display Replacement, Removing the Power Connector Cable: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull directly up on the light blue tab.
  6. Dell Inspiron 1420 Display Replacement, VGA cable: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1420 Display Replacement, VGA cable: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1420 Display Replacement, VGA cable: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Squeeze the two metal clips located on the VGA cable.
    • Pull while squeezing the clips in order to remove the cable.
  7. Dell Inspiron 1420 Display Replacement, Isolating the Display: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1420 Display Replacement, Isolating the Display: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1420 Display Replacement, Isolating the Display: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the three 3mm screws located on both the left and right side of the laptop.
    • Remove the metal brackets, one on each side, by gently pulling.
Kris Karanxha
crwdns2935283:009/23/14crwdne2935283:0
298 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-4, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 2-4, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S2G4
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 2,606
