Dell Inspiron 1420 Disassembly
  1. Dell Inspiron 1420 Disassembly, Remove Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1420 Disassembly, Remove Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press both indicated locks on the bottom side of the laptop to release and remove the battery.
  2. Dell Inspiron 1420 Disassembly, Unscrew Back Panel Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1420 Disassembly, Unscrew Back Panel Screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen and remove indicated screws on the back panel using a Phillips #1 screwdriver.
    • Back cover screws
    • These screws are a different length than the others and can be stored separately for reassembly.
    • Hard drive cover screws
    • RAM cover screws
    • CD drive cover screw
    • Heat sink cover screws
  3. Dell Inspiron 1420 Disassembly, Remove Hard Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hard drive cover.
    • Pull the tab in the direction of the arrows to remove the hard drive.
  4. Dell Inspiron 1420 Disassembly, Remove CD Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1420 Disassembly, Remove CD Drive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a screwdriver, slide out the CD drive bracket enough for it to be grabbed.
    • Remove CD drive from housing.
  5. Dell Inspiron 1420 Disassembly, Remove RAM: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1420 Disassembly, Remove RAM: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove RAM cover.
    • Pull the metal tabs above and below the RAM outward and remove both RAM sticks.
  6. Dell Inspiron 1420 Disassembly, Remove Heat Sink: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1420 Disassembly, Remove Heat Sink: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1420 Disassembly, Remove Heat Sink: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the heat sink cover.
    • Using a Phillips #1 screwdriver, loosen and remove screws from heat sink.
    • Remove the heat sink.
  7. Dell Inspiron 1420 Disassembly, Remove CPU: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1420 Disassembly, Remove CPU: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1420 Disassembly, Remove CPU: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a flathead screwdriver, quarter turn the screw anticlockwise to release the CPU.
    • Gently lift the CPU out of the housing.
    • The pins on the bottom of the CPU are very fragile and will not function if any are bent.
  8. Dell Inspiron 1420 Disassembly, Remove Bracket: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1420 Disassembly, Remove Bracket: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, unscrew and remove bracket.
    • There may be a card along with the bracket in your machine. If there is, unplug and remove this card as well.
  9. Dell Inspiron 1420 Disassembly, Remove Back Screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #1 screwdriver, loosen and remove the indicated screws.
  10. Dell Inspiron 1420 Disassembly, Pry Control Panel: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to pry off the control panel.
  11. Dell Inspiron 1420 Disassembly, Pry Hinge Covers: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to pry off the hinge covers.
  12. Dell Inspiron 1420 Disassembly, Remove Keyboard Screws: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #1 screwdriver, loosen and remove the keyboard screws.
  13. Dell Inspiron 1420 Disassembly, Remove Keyboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1420 Disassembly, Remove Keyboard: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift keyboard to reveal blue ribbon connection.
    • Use a spudger to flip the blue ribbon lever and release the keyboard.
  14. Dell Inspiron 1420 Disassembly, Remove Wifi-Card: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1420 Disassembly, Remove Wifi-Card: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the screw holding in the Wi-Fi card.
    • Unplug cables connected to Wi-Fi card.
    • Slide Wi-Fi card out of connection to remove.
  15. Dell Inspiron 1420 Disassembly, Lift Control Panel: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1420 Disassembly, Lift Control Panel: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, loosen and remove control panel screw.
    • Carefully pull up control panel. Being sure to keep the cable attached, set to the side.
  16. Dell Inspiron 1420 Disassembly, Remove Monitor: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1420 Disassembly, Remove Monitor: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the blue tab up to release the monitor.
    • Remove monitor.
  17. Dell Inspiron 1420 Disassembly, Remove Screws: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove remaining screws from cover panel.
  18. Dell Inspiron 1420 Disassembly, Unplug Connections: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1420 Disassembly, Unplug Connections: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1420 Disassembly, Unplug Connections: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, disconnect control panel motherboard cable.
    • Using a spudger, flip up blue lever and disconnect touchpad cable.
  19. Dell Inspiron 1420 Disassembly, Remove Screws and Connections: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift off cover panel.
    • Using a Phillips #1 screwdriver, loosen and remove screws from motherboard.
    • Disconnect the indicated cables from the motherboard.
  20. Dell Inspiron 1420 Disassembly, Remove SIM Board: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove screw.
    • Disconnect indicated cable and remove SIM board.
  21. Dell Inspiron 1420 Disassembly, Remove Memory Card Holder: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide memory card holder out of housing.
  22. Dell Inspiron 1420 Disassembly, Remove Modem Card: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip laptop over to show backplate.
    • Loosen and remove modem card screw using a Phillips #1 screwdriver.
    • Remove modem card.
  23. Dell Inspiron 1420 Disassembly, Release Motherboard: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1420 Disassembly, Release Motherboard: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip laptop over and gently pull motherboard away from backplate.
    • Disconnect the indicated connection to release the motherboard.
Braxton Quillin
crwdns2935283:011/07/24crwdne2935283:0
184 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 202
