Dell Inspiron 14-7437 Thermal Cooling Fan Replacement
  1. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Base Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Base Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry open the back cover using a spudger and slide it along the under the cover.
  3. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
  4. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the ribbon cables from the motherboard.
  5. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up and remove the Lithium-Polymer Battery.
  6. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Speaker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect wires from Motherboard by gently pulling up.
  7. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the speakers from the case.
  8. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Coin Cell Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the coin cell battery wire, and carefully remove from motherboard.
    • There are little hooks that the wire is hooked under.
  9. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Coin-Cell Battery from the case.
    • There is a small amount of adhesive on the bottom of the coin cell battery.
  10. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Cooling Fan: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Cooling Fan: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 2.5 mm screws using a J000 Phillips Head Screwdriver.
  11. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull up on the wire and remove the Cooling Fan.
  12. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Thermal-Cooling Assembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Thermal-Cooling Assembly: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Thermal-Cooling Assembly: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect cables connected to the motherboard by lifting the flaps up and pulling out.
    • This is a ZIF connector and needs to have the side flaps flipped up before removal.
    • The ZIF connector has small clips that need to be pulled up before being pulled out.
  13. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the eight 2.5 mm screws using a J000 Phillips Head Screwdriver.
  14. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the motherboard.
  15. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the three 2.5 mm screws using the J000 Phillips Head Screwdriver.
    • These three 2.5 mm screws cannot be removed from the Thermal Cooling assembly.
  16. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Thermal-Cooling Assembly from the motherboard.
Katelyn Remy
crwdns2935283:003/10/16crwdne2935283:0
449 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 7-8, Catania Spring 2016 crwdns2935289:0UMass Dartmouth, Team 7-8, Catania Spring 2016crwdne2935289:0
UMASSD-CATANIA-S16S7G8
crwdns2942667:0crwdne2942667:0 1,197
