This guide will cover the steps needed to repair a faulty Wi-Fi card for the Dell Inspiron 14-5447 laptop. Make sure that prior to starting this guide, the device is not plugged into any power source and it is turned off.
Flip the laptop upside down to access the battery.
Remove the two black 5.70mm Phillips#0 screws on the case's back.
Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
Use the black, plastic flap on the left side to pull the battery out.
Slowly lift the flap up and the battery should slide out.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Locate the Wifi card on the top left of the laptop.
Use the tweezers to release the black and white cables.
Remove one silver 2.9mm Phillips #1 screw which secures the WiFi card.
Use tweezers to push the white part of the Wi-Fi card up towards the top of the device to remove.
Remove the card with the tweezers.
