Dell Inspiron 14 5100 Motherboard Replacement
  1. Dell Inspiron 14 5100 Motherboard Replacement, Dell Inspiron 14 5100 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 14 5100 Motherboard Replacement, Dell Inspiron 14 5100 Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 14 5100 Motherboard Replacement, Dell Inspiron 14 5100 Disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Motherboard Replacement, RAM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fold back the thin plastic covers over the RAM slots.
  4. Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, pull back the pins holding the RAM in place.
    • The RAM will slightly pop up from the motherboard.
  5. Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the RAM card from the RAM slot using your fingers. Pull it gently in the direction of the laptop hinge.
    • Repeat Steps 3-5 for the other RAM slot.
  6. Dell Inspiron 14 5100 Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the white connector from the motherboard using the spudger.
  7. Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip up the retaining flap and remove the blue ribbon cable from its connector on the motherboard using a spudger.
  8. Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip up the retaining flap and remove the orange ribbon cable from its connector on the motherboard using a spudger.
  9. Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the CMOS battery connector using the spudger.
  10. Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black connector using the spudger.
  11. Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 3 mm screw from the Wi-Fi card using the Phillips #0 screwdriver.
    • Pull the Wi-Fi card out of the slot and set aside.
  12. Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single screw from the SSD using the Phillips #0 screwdriver.
    • Remove the SSD from the motherboard.
  13. Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 2 mm screws using the Phillips #0 screwdriver.
  14. Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the cable from its connector on the motherboard using the spudger.
  15. Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the metal retaining flap using the opening tool.
    • Remove the connector from the bracket.
  16. Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the cable using the spudger.
  17. Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the connector using the spudger.
  18. Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove six 3 mm screws using the Phillips #0 screwdriver.
  19. Dell Inspiron 14 5100 Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard by lifting it from the rear and then completely removing it from the laptop.
Meth Ranaweera
crwdns2935283:009/20/21crwdne2935283:0
436 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team 2-15, Eggleston Fall 2021 crwdns2935289:0The Citadel Military College of South Carolina, Team 2-15, Eggleston Fall 2021crwdne2935289:0
CMCSC-EGGLESTON-F21S2G15
crwdns2942667:0crwdne2942667:0 835
