Dell Inspiron 13z 5323 Battery Replacement
  1. Dell Inspiron 13z 5323 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13z 5323 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13z 5323 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove nine screws from the bottom case.
    • The highlighted captive screw on the base cover is held in place with a washer, so when it is loosened and the cover is removed, the screw will stay in the plate.
    • Once the captive screw is loosened, remove the small base cover on the bottom of the device.
  2. Dell Inspiron 13z 5323 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13z 5323 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13z 5323 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are 3 slots on the top of the keyboard where you will have to use a thin tool, such as a flathead screwdriver to push the tabs so the keyboard will pop out.
    • Be careful when pushing in the keyboard tabs, as they may break if they if too much pressure is applied to them.
    • You will have to flip a small tab up where the ribbon connector goes into the insert, so the connector can be released and the keyboard can be removed.
  3. Dell Inspiron 13z 5323 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13z 5323 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13z 5323 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the highlighted 4 screws and then use the plastic separator to remove the palm rest.
    • Be careful when separating the palm rest from the laptop, because being too aggressive with it can cause the small clips that hold the palm rest in place to break .
  4. Dell Inspiron 13z 5323 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13z 5323 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13z 5323 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screws surrounding the battery and unplug the cable in the top left corner to then remove the battery.
Chase Hussey
crwdns2935283:003/08/17crwdne2935283:0
201 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S5-G6, Botvin Spring 2017 crwdns2935289:0UMass Dartmouth, Team S5-G6, Botvin Spring 2017crwdne2935289:0
UMASSD-BOTVIN-S17S5G6
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 950
