Dell Inspiron 13-7373 Motherboard Replacement
  1. Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Motherboard Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four screws holding the battery in place.
  3. Dell Inspiron 13-7373 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 13-7373 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the plastic tab on the battery cable to disconnect the cable from the battery.
  4. Dell Inspiron 13-7373 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 13-7373 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery from the laptop.
  5. Dell Inspiron 13-7373 Motherboard Replacement, Fan: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws holding the cover for the fan.
  6. Dell Inspiron 13-7373 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
  7. Dell Inspiron 13-7373 Motherboard Replacement, Network Card: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
  8. Dell Inspiron 13-7373 Motherboard Replacement, Daughterboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
    • Remove the metal piece holding in the daughterboard.
    • Disconnect the two cable connectors from the daughterboard.
    • If the cables are stuck, gently wiggle them until they disconnect.
  9. Dell Inspiron 13-7373 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the daughterboard.
  10. Dell Inspiron 13-7373 Motherboard Replacement, Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven 2mm screws securing the motherboard.
  11. Dell Inspiron 13-7373 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7373 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7373 Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Release the IO Board Cable.
    • Release the Touchpad cable.
    • Release the keyboard back-light cable.
    • Release the keyboard cable.
    • Release the eDP cable.
    • Release the dc-in cable.
    • Release the cable for the LED charging indicator by gently pulling up on the connector.
  12. Dell Inspiron 13-7373 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift up on the motherboard to remove it.
John Egan
crwdns2935283:010/25/19crwdne2935283:0
485 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 crwdns2935289:0UMass Dartmouth, Team S1-G4, O'Connell Fall 2019crwdne2935289:0
UMASSD-O'CONNELL-F19S1G4
crwdns2942667:0crwdne2942667:0 1,575
