Dell Inspiron 13-7373 Fan Replacement
  1. Dell Inspiron 13-7373 Fan Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7373 Fan Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7373 Fan Replacement, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
    On the outer part of the hinges there is 1 clip on each side that also need to be snapped out with the opening tool. You will hear a click noise when they are out.
    Sandi - crwdns2934203:0crwdne2934203:0
  2. Dell Inspiron 13-7373 Fan Replacement, Fan: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws holding the cover for the fan.
  3. Dell Inspiron 13-7373 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
To reassemble your device with the new fan, follow these instructions in reverse order.
Kameron Jusseaume
crwdns2935283:010/25/19crwdne2935283:0
492 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 crwdns2935289:0UMass Dartmouth, Team S1-G4, O'Connell Fall 2019crwdne2935289:0
UMASSD-O'CONNELL-F19S1G4
This was most helpful. We have a Dell 7373 model and the fan is quite noisy. We are going to disassemble and clean/replace it. Your tutorial explained it all. Thank you.
martyfukui - crwdns2934203:0crwdne2934203:0
these 7373 seem to have a fan issue- I do IT for a business that has like 10 of them and at least 2 developed the same issue after a couple years- ordered new fans off of Amazon (tons of them and all look same except some have a flange on the bottom?) and no way to differentiate quality- both redeveloped the problem soon after installing fan- both were clean inside w no obvious issue- guessing the thin case has possibly bent down a tad and puts pressure on it- might take apart and see if I can bend part of case out a bit?) geez dell.
Garry Masters - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 1,308
