Dell Inspiron 13-7359 Battery Replacement
  1. Dell Inspiron 13-7359 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7359 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7359 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7359 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7359 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
Valentin Medina
crwdns2935283:001/30/18crwdne2935283:0
703 crwdns2915208:0crwdne2915208:0
Baylor, Team S1-G6, Johnson Spring 2018 crwdns2935289:0Baylor, Team S1-G6, Johnson Spring 2018crwdne2935289:0
BU-JOHNSON-S18S1G6
thanks for this, my daughter’s laptop now needs a new battery and while I assumed it would be easy, it’s good to get a preview.
Paul M - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 1,689
