This is a simple step-by-step guide on how to remove and replace a webcam for a Dell Inspiron 13-5368. You will need a Philips Head J-0 screwdriver and a pry tool in order to perform this task. This task requires a great amount of care because you are working with glass and will take approximately 15 minutes to complete.
Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
Use a spudger / pry tool to pry up and remove the back cover.
Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
Lift the battery straight up out of the housing.
Unscrew the 2mm screw that holds the WLAN card. Then carefully remove the WLAN card from the motherboard.
Detach the black and white antenna cables from the WLAN card.
Unscrew the screws that are securing the laptop's hinges.
Use your plastic opening tool to pry the LCD back cover from the display panel.
Carefully separate the back cover from the LCD screen.
Carefully remove the ribbon cable that holds the webcam to the screen, then unplug the webcam from the ribbon cable.
