Dell Inspiron 13-5368 Heatsink Replacement
  1. Dell Inspiron 13-5368 Heatsink Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-5368 Heatsink Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-5368 Heatsink Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
    Note that Dell Inspiron 13s have had a rash of bad batteries that swell as they age, causing them to press hard against the trackpad. This can cause it to track poorly or make it difficult or impossible to left or right click the pad. Replacing the bad battery often fixes these kind of trackpad issues on these models where the battery is directly under the trackpad.
    Heath Connett - crwdns2934203:0crwdne2934203:0
  2. Dell Inspiron 13-5368 Heatsink Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 13-5368 Heatsink Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger / pry tool to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Heatsink Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Heatsink Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
    In what direction should I pull the tab. And how should I hold it
    Bam - crwdns2934203:0crwdne2934203:0
  5. Dell Inspiron 13-5368 Heatsink Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 13-5368 Heatsink Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery straight up out of the housing.
  6. Dell Inspiron 13-5368 Heatsink Replacement, Heatsink: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 13-5368 Heatsink Replacement, Heatsink: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four screws securing the heatsink and remove it.
    • Remember to reapply a small amount of thermal paste, then screw the heatsink onto the motherboard in numberical order (i.e. 1, 2, 3, 4).
Remember to clean off any old thermal paste, then apply a small amount of new thermal paste (dime size will be fine). Screw the heatsink on in numerical order so the thermal paste is evenly distributed on the processor. To reassemble your device, follow these instructions in reverse order.
Matt Sugrim
crwdns2935283:009/27/17crwdne2935283:0
1.066 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S14-G6, Boczar Fall 2017 crwdns2935289:0USF Tampa, Team S14-G6, Boczar Fall 2017crwdne2935289:0
USFT-BOCZAR-F17S14G6
crwdns2935297:013crwdne2935297:0
Is it normal for the heatsink to be loose right in front of the fan? The black part of the heatsink?
JRaje - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 763
