Dell Inspiron 1200 Display Assembly Replacement
  1. Dell Inspiron 1200 Display Assembly Replacement, Disconnecting the Ground Wire: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1200 Display Assembly Replacement, Disconnecting the Ground Wire: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  2. Dell Inspiron 1200 Display Assembly Replacement, Remove the Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four M2.5 x 5-mm screws (labeled "M2.5x5") that secure the EMI shield to the system board.
  3. Dell Inspiron 1200 Display Assembly Replacement, Releasing the Retention Tabs: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the EMI shield out of the computer baseby rotating the front upwards then lifting to release the retention tabs from the retention-tab slots.
  4. Dell Inspiron 1200 Display Assembly Replacement, Disconnecting the Antenna Cable: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the attached antenna cable from the Mini PCI card.
    • Close the display.
    • From the bottom of the computer, remove the two M2.5 x 5-mm screws labeled "D."
  5. Dell Inspiron 1200 Display Assembly Replacement, Remove the Screws: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From the back of the computer, remove the two M2.5 x 8-mm screws labeled "D."
  6. Dell Inspiron 1200 Display Assembly Replacement, Pull the Pull-Tab: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1200 Display Assembly Replacement, Pull the Pull-Tab: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
  7. Dell Inspiron 1200 Display Assembly Replacement, Removing the Cables: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the Mini PCI card antenna cable and the display cables from their routing guides.
  8. Dell Inspiron 1200 Display Assembly Replacement, Lifting the Display Assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the display assembly out of the computer base.
Terrence15
crwdns2935283:012/18/17crwdne2935283:0
79,675 crwdns2915208:0crwdne2915208:0
crwdns2935297:0441crwdne2935297:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01,991crwdne2935297:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 269
