Dell Inspiron 11z-1121 Memory Modules Replacement
  1. Dell Inspiron 11z-1121 Memory Modules Replacement, Loosen the Screw: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  2. Dell Inspiron 11z-1121 Memory Modules Replacement, Lifting the Memory-Module Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the memory-module cover off the computer base.
  3. Dell Inspiron 11z-1121 Memory Modules Replacement, Popping up the Memory Module: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  4. Dell Inspiron 11z-1121 Memory Modules Replacement, Removing the Memory Module: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the memory module from the memory-module connector.
  5. Dell Inspiron 11z-1121 Memory Modules Replacement, Align the Notch: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  6. Dell Inspiron 11z-1121 Memory Modules Replacement, Sliding the Memory Module: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11z-1121 Memory Modules Replacement, Sliding the Memory Module: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the memory module firmly into the memory-module connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
  7. Dell Inspiron 11z-1121 Memory Modules Replacement, Sliding the Tabs: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the tabs on the memory-module cover into the slots on the computer base and gently press the memory-module cover into place.
  8. Dell Inspiron 11z-1121 Memory Modules Replacement, Tighten the Screw: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tighten the screw that secures the memory-module cover to the computer base.
Terrence15
crwdns2935283:012/18/17crwdne2935283:0
79,675 crwdns2915208:0crwdne2915208:0
crwdns2935297:0441crwdne2935297:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01,991crwdne2935297:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 186
