Dell Inspiron 11z-1121 Hard Drive Replacement
  1. Dell Inspiron 11z-1121 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11z-1121 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the latches outward to release the battery.
    • Pull the battery outward to remove.
    • The latches should lock in place, allowing for easy removal.
    • The battery must be removed for safety reasons when replacing other components of the laptop.
  2. Dell Inspiron 11z-1121 Hard Drive Replacement, Keyboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11z-1121 Hard Drive Replacement, Keyboard: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew three black 1mm screws using the PH1 Phillips-head screwdriver on the bottom of the laptop around the battery.
  3. Dell Inspiron 11z-1121 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11z-1121 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over and open it to expose the keyboard.
    • Use a plastic opening tool to pry up the keyboard, starting in the upper corner and working your way around.
    • Once the keyboard is pried up, do not remove the keyboard. There is still a ribbon attaching the keyboard to the laptop.
  4. Dell Inspiron 11z-1121 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11z-1121 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the keyboard to expose the ribbon attaching the keyboard to the laptop.
    • Flip up the black retaining flap on the ZIF connector and then pull the ribbon cable away.
    • Remove the keyboard from the laptop.
  5. Dell Inspiron 11z-1121 Hard Drive Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The hard drive will be a silver rectangle. Slide the hard drive to the right to remove.
    • To be safe, make sure you either wear an anti-static wrist band, or rub your hands against a metal object to remove any static.
Brandan Eng
crwdns2935283:010/04/16crwdne2935283:0
143 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-5, Nance Fall 2016 crwdns2935289:0USF Tampa, Team 1-5, Nance Fall 2016crwdne2935289:0
USFT-NANCE-F16S1G5
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 2,073
