Dell Inspiron 11-3180 Battery Replacement
  1. Dell Inspiron 11-3180 Battery Replacement, Bottom Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the Chromebook to have the bottom facing you.
    • Make a note of all of the screws present. You may need to uncover some of them hidden beneath plastic tabs. The location of each screw is marked in the accompanying image.
  2. Dell Inspiron 11-3180 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all nine of the 6 mm screws on the bottom with a size #00 Phillips screwdriver.
    • If needed, use a toothpick or the tip of your screwdriver to uncover the plastic that's hiding them.
  3. Dell Inspiron 11-3180 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the Chromebook upright and open it.
  4. Dell Inspiron 11-3180 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the iFixit plastic opening tool, wedge it into the seam of the bottom plate. This will create a small gap between the sections that you can gently pry open. Work your way around to each side of the device until the bottom pops free.
    • Caution: DO NOT attempt to fully remove the bottom plate yet, as there are still connected wires. Doing so may result in damage to your device.
  5. Dell Inspiron 11-3180 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have pried enough space between the Chromebook and the bottom plate, flip it back over so the bottom plate is facing you and gently pull it up with your hands.
  6. Dell Inspiron 11-3180 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you completely pull off the back, you must disconnect the MB cord.
    • Using blunt-nosed tweezers, carefully flip the black bar that keeps the MB cord latched in as circled in the image.
    • Once open, grab the flat cord with your tweezers and pull horizontally until it comes free. Your bottom plate is now fully removed.
  7. Dell Inspiron 11-3180 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finally, pull off the bottom plate carefully and set it to the side to continue with your needed repairs or replacements.
  8. Dell Inspiron 11-3180 Battery Replacement, Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the battery on the lower half of the open laptop.
    • Using blunt-nosed tweezers, carefully disconnect the battery cable from the service board by pulling at the small plastic tabs on either side.
  9. Dell Inspiron 11-3180 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11-3180 Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a #00 Phillips screwdriver to remove the six 4 mm screws.
    • Also remove the one 6 mm screw.
    • Not all screws are pictured, but the locations are circled.
    • There should no longer be any screws holding down the battery.
  10. Dell Inspiron 11-3180 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the battery with hands.
Ivy Taylor
crwdns2935283:010/02/23crwdne2935283:0
653 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team 1-1, Karnes Fall 2023 crwdns2935289:0Linn Benton Community College, Team 1-1, Karnes Fall 2023crwdne2935289:0
LBCC-KARNES-F23S1G1
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 607
