Dell Inspiron 11-3164 Keyboard Replacement
  1. Dell Inspiron 11-3164 Keyboard Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11-3164 Keyboard Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place laptop upside down to observe the first set of screws on the bottom cover. With the J1 Phillips head screwdriver bit, unscrew eight (8) size 60 mm screws.
    • With a metal spudger, remove the plastic cover to unveil the final screw.
    • With the J1 Phillips head bit, remove remaining 60 mm screw.
  2. Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a metal spudger, pry apart the bottom cover working around the edges.
    • While separating the halves of the bottom cover, carefully move the spudger up and down to avoid damaging the USB/Audio circuit board cable inside.
    • With tweezers, disconnect the USB/Audio circuit board cable.
    • Place the bottom cover off to the side.
  3. Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the J1 screwdriver bit, unscrew three (3) size 40 mm battery screws.
  4. Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With tweezers, disconnect the battery cable.
    • Remove the battery pack.
  5. Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the M2 x 3mm bracket screw.
    • Remove the metal bracket.
    • With tweezers, detach the white and black antenna cables connected to the Wireless WLAN Card.
    • Remove the Wireless WLAN Card.
  6. Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With tweezers, unplug the CMOS battery.
    • With tweezers, detach the CMOS battery.
  7. Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With tweezers, unplug the DC Jack cable.
    • With the Philips #0 Screwdriver, loosen the M2 x 3mm screw.
    • With tweezers, detach the DC Jack.
  8. Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With tweezers, disconnect the speaker cable.
    • With tweezers, detach the speaker.
  9. Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the Philips #0 Screwdriver, unbolt the M2 x 3mm screw.
    • With tweezers, disconnect the display cable.
  10. Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the Philips #0 Screwdriver, unfasten the 2 - M2.5 x 5mm left and right hinge screws.
    • With the Philips #0 Screwdriver, unhinge the 2 - M2.5 x 5mm display cable bracket screw.
    • With tweezers, remove the LCD screen.
  11. Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the Philips #0 Screwdriver, loosen the 4 screws supporting the copper plate.
    • With tweezers, remove the copper plate.
  12. Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11-3164 Keyboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With tweezers, disconnect the keyboard cable.
    • With tweezers, disconnect the touchpad cable.
    • With the Philips #00 Screwdriver, loosen the four (4) M2 x 2mm screws.
    • Gently remove the mouse touchpad. The fixer is left with the palm-rest and keyboard assembly.
Michael Kendziora
crwdns2935283:002/14/18crwdne2935283:0
781 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S6-G4, Eyestone Spring 2018 crwdns2935289:0USF Tampa, Team S6-G4, Eyestone Spring 2018crwdne2935289:0
USFT-EYESTONE-S18S6G4
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 417
