Dell Inspiron 11-3162 Palmrest Keyboard Replacement
  1. Dell Inspiron 11-3162 Palmrest Keyboard Replacement, Back Cover Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11-3162 Palmrest Keyboard Replacement, Back Cover Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use tweezers to pry and remove the center screw cover on the back cover.
  2. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
  3. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
    • Do not fully remove the cover, as it is still attached to the laptop with cables.
  4. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you are only replacing the battery, you can skip this step. Be careful not to strain the still-connected cable as you work.
    • Unlock the wide ZIF connector securing the flex cable.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
    • Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
  5. Dell Inspiron 11-3162 Palmrest Keyboard Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11-3162 Palmrest Keyboard Replacement, Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
  6. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers (or a set of tweezers) to disconnect the battery cable from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Lift and remove the battery from its recess.
  7. Dell Inspiron 11-3162 Palmrest Keyboard Replacement, Wireless WLAN Card: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11-3162 Palmrest Keyboard Replacement, Wireless WLAN Card: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
  8. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers, pull the white and black wires off of the WiFi Chip.
  9. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the WiFi Chip.
  10. Dell Inspiron 11-3162 Palmrest Keyboard Replacement, Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the tweezers to unplug the DC Jack.
  11. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the tweezers unplug the Speaker Cable.
  12. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the tweezers to remove the CMOS Cable.
  13. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the tweezers to remove the Touchpad Cable.
  14. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the phillips screwdriver with the PH0 to loosen the 4 screws and remove the orange plate.
  15. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the phillips screwdriver with the PH00 head to unscrew the one 3mm screw. Then, remove the bracket.
  16. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the keyboard cable.
  17. Dell Inspiron 11-3162 Palmrest Keyboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard by gently lifting upwards from the edges.
  18. Dell Inspiron 11-3162 Palmrest Keyboard Replacement, Palmrest Keyboard: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently grip and pull the speaker to remove it.
    • Now you've removed the Palmrest keyboard!
Jared Johnson
crwdns2935283:009/29/16crwdne2935283:0
589 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-2, Crane Fall 2016 crwdns2935289:0Eastern Washington University, Team 1-2, Crane Fall 2016crwdne2935289:0
EWU-CRANE-F16S1G2
crwdns2942667:0crwdne2942667:0 1,033
