Dell E193FPc Interface Buttons Replacement
crwdns2869540:0crwdne2869540:0: 2985
4
19
94
2.985
crwdns2955950:0crwdne2955950:0: 1
crwdns2960006:01crwdne2960006:0
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2959986:0crwdne2959986:0: 6
crwdns2959982:06crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:010crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
Replace the interface buttons if they have fallen out or are worn out from usage.
    1. Dell E193FPc Interface Buttons Replacement, Stand: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lay the monitor screen-down so the back screws are exposed.
      • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
    2. Dell E193FPc Interface Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently lift and pull away the stand at a slight angle away from the monitor.
    1. Dell E193FPc Interface Buttons Replacement, Display Bezel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell E193FPc Interface Buttons Replacement, Display Bezel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the two holes on the bottom of the monitor.
      • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
      • This task is much easier if two people pry simultaneously at each hole.
      • Continue prying along the entire edge of the monitor.
    2. Dell E193FPc Interface Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell E193FPc Interface Buttons Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • When finished prying, the plastic will partially fall away from the rest of the monitor.
      • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
      • While holding the frames together, carefully flip the monitor over so it faces screen down.
      • Gently lift and remove remove the rear case from the monitor.
    3. Dell E193FPc Interface Buttons Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell E193FPc Interface Buttons Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell E193FPc Interface Buttons Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the green interface button board.
      • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
      • Lift the monitor interior away from the front cover.
    1. Dell E193FPc Interface Buttons Replacement, Interface Buttons: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Behind the front panel of the plastic cover lies the button strip.
      • Remove the buttons by gently pulling up on the strip.
      • You may have to pry the plastic strip up with a prying tool or spudger to remove it.
Charley Grove
crwdns2935283:010/10/11crwdne2935283:0
Cal Poly, Team 5-36, Amido Fall 2011 crwdns2935289:0Cal Poly, Team 5-36, Amido Fall 2011crwdne2935289:0
CPSU-AMIDO-F11S5G36
and then…?! you cant buy replacement buttons!! so now what?!
Sarah Barnes - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 94
crwdns2959996:0crwdne2959996:0 2,985
