Dell E193FPc Display Bezel Replacement
  1. Dell E193FPc Display Bezel Replacement, Stand: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the monitor screen-down so the back screws are exposed.
    • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
  2. Dell E193FPc Display Bezel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift and pull away the stand at a slight angle away from the monitor.
  3. Dell E193FPc Display Bezel Replacement, Display Bezel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell E193FPc Display Bezel Replacement, Display Bezel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the two holes on the bottom of the monitor.
    • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
    • This task is much easier if two people pry simultaneously at each hole.
    • Continue prying along the entire edge of the monitor.
  4. Dell E193FPc Display Bezel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell E193FPc Display Bezel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When finished prying, the plastic will partially fall away from the rest of the monitor.
    • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
    • While holding the frames together, carefully flip the monitor over so it faces screen down.
    • Gently lift and remove remove the rear case from the monitor.
  5. Dell E193FPc Display Bezel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell E193FPc Display Bezel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell E193FPc Display Bezel Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the green interface button board.
    • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
    • Lift the monitor interior away from the front cover.
crwdns2935229:05crwdne2935229:0
Mackenzie Keane
crwdns2935283:010/04/11crwdne2935283:0
514 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-36, Amido Fall 2011 crwdns2935289:0Cal Poly, Team 5-36, Amido Fall 2011crwdne2935289:0
CPSU-AMIDO-F11S5G36
crwdns2942667:0crwdne2942667:0 4,546
