Dell Dimension 2300 Hard Drive Replacement
    • Shut down the computer through the Start menu.
    • Ensure that your computer and attached devices are turned off. If your computer and attached devices did not automatically turn off when you shut down your computer, turn them off now.
    While i switch on computer not start. Does it have fuse inside? Shall i check it first?
    Daniel Hailemariam - crwdns2934203:0crwdne2934203:0
    • Remove the bracket-securing screw, and then remove the drive bracket from the computer.
    • Remove the hard drive-securing screw, and then remove the hard drive from the bracket.
    • Install the new hard drive in the bracket. Place the hard drive in the bracket so that the two screw-hole tabs insert into the two screw holes on the hard drive, and then secure the drive to the bracket with the screw that you removed.
James Walker
crwdns2935283:010/04/17crwdne2935283:0
368 crwdns2915208:0crwdne2915208:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01.991crwdne2935297:0
Some pictures would be nice.
guardian10 - crwdns2934203:0crwdne2934203:0
No power arrived while i switch on the button of compiutor
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 2,625
