Dell DJ Motherboard Replacement
  1. Dell DJ Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell DJ Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell DJ Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the metal spudger, carefully slide it under the black rubber bottom to remove it.
    • Using a Phillips J000 head screw driver, unscrew the 4mm screws placed on the outer corners of the metal plate.
    • Again, take the metal spudger, placing it under the metal plate to take it off.
  2. Dell DJ Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell DJ Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell DJ Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the metal plate is off, inspect the inside of the device to be sure the battery is plugged in and there's nothing blocking it.
    • Battery malfunction is often caused by internal components that are dirty. Be sure the battery clip is plugged in properly and then reassemble device. Hold the power button and start the device up.
  3. Dell DJ Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell DJ Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If the battery is still malfunctioning, carefully unplug the battery using tweezers.
    • Gently place the tweezers on either side of the batter to slide it out of the shell.
  4. Dell DJ Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell DJ Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell DJ Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To replace the battery, simply insert a new one into the same slot and then plug in the end to the correct spot.
    • After the device is assembled, power the device on. The issue should be repaired.
    • If the device battery is still defective, a greater issue is the cause.
    https://www.ebay.com/itm/New-3-7V-1500mA...
    This battery will fit and works great. The normal ones listed on E bay are too thick. I did solder the connector rather than replace.
    Dimensions: 85x48x3mm
    Dalbani Base Category: Batteries Voltage: 3.7 V Amperage: 1500mAh Dalbani Item Number: 29-16-0658
    MPN: 29-16-0658 1500mAh 3.7V Internal Battery Chemical Composition: Li-Ion
    Glenn Klein - crwdns2934203:0crwdne2934203:0
  5. Dell DJ Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell DJ Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Inspect your device and be sure that it matches the device that this guide is disassembling.
    • Familiarize yourself with the specific design of the device.
    • Battery replacement is the only repair that our guide offers that does not require a complete tear down.
  6. Dell DJ Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell DJ Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell DJ Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The top plate of the device is attached by a dot of glue. Use the metal spudger to pry the plate off.
    • After the top plate is removed, remove the four 4mm screws that attach the inner plate.
    • When the plate is removed, the motherboard will be ready to be removed.
  7. Dell DJ Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell DJ Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell DJ Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the motherboard out of the protective case.
    • Be careful not to snag any wires.
    • When the motherboard is exposed the device is ready to be inspected and repaired.
William Abel
crwdns2935283:001/28/16crwdne2935283:0
164 crwdns2915208:0crwdne2915208:0
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2016 crwdns2935289:0USF Sarasota-Manatee, Team 1-1, Stewart Spring 2016crwdne2935289:0
USFSM-STEWART-S16S1G1
How did you get the logic board to slide past the scroll wheel ?
kf4qic - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 736
