This guide should be followed closely before attempting to repair your device. Follow the steps in great detail to ensure the success of your repair.
Inspect your device and be sure that it matches the device that this guide is disassembling.
Familiarize yourself with the specific design of the device.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Remove the bottom panel with the metal spudger. This panel may be fused to the outer shell with a dot of adhesive.
Four screws fasten a metal plate to the device. Using the device magnetic mat and 54 bit (Phillips J000) driver, remove the screws.
The top plate of the device is attached by a dot of glue. Use the metal spudger to pry the plate off.
After the top plate is removed, remove the four 4mm screws that attach the inner plate.
When the plate is removed, the motherboard will be ready to be removed.
Slide the motherboard out of the protective case.
When the motherboard is exposed the device is ready to be inspected and repaired.
crwdns2917034:0crwdne2917034:0
How did you get the logic board to slide past the scroll wheel ?
