Dell Chromebook 5190 Battery Replacement
  1. Dell Chromebook 5190 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before starting, please make sure you have disconnected and removed all devices populating the laptop's ports.
    • Remove the nine M2.5x7.5 screws located on the bottom side of the laptop.
  2. Dell Chromebook 5190 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Chromebook 5190 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Chromebook 5190 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be cautious, the following instructions are to prevent cracking the base cover.
    • With the opening tool, pry open the upper left corner by the laptop hinge.
    • With the opening tool, pry open the upper right corner by the laptop hinge.
    • Lift off base cover.
  3. Dell Chromebook 5190 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 5190 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top left side of the battery.
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top right side of the battery.
  4. Dell Chromebook 5190 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 5190 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the clear adhesive tape on the system board from the battery cable from where it's seated above the battery.
    • Pull out the keyboard cable toward you to disconnect it.
  5. Dell Chromebook 5190 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 5190 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black adhesive tape on the system board from the battery cable.
    • Dismount the cable from where it's seated above the battery.
  6. Dell Chromebook 5190 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Chromebook 5190 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Chromebook 5190 Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew and remove the four M2x3 screws on each corner of the battery.
    • Dismount the battery.
Denise Cano
crwdns2935283:002/10/22crwdne2935283:0
617 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-3, Pee Spring 2022 crwdns2935289:0Gateway, Team 1-3, Pee Spring 2022crwdne2935289:0
GCC-PEE-S22S1G3
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 723
