Dell Chromebook 3180 Charging Port Replacement
  1. Dell Chromebook 3180 Charging Port Replacement, Remove Bottom Cover / Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 3180 Charging Port Replacement, Remove Bottom Cover / Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 7 screws from the back cover with a Phillips #0 screwdriver
    • Once all 7 screws have been removed, you can start to pry apart the back cover with your Plastic Blade or your fingers. (See pic)
    • Using a Phillips #0, remove the 2 screws from the right side hinge.
    • Lift the chromebook base in order to force the hinge in an upward position. This will provide you enough room to remove the charging port.
    • Remove the 2 charging port screws
    • Unplug the charging port connector from the Motherboard
    • Disconnect the charging port connector from the motherboard.
    • Replace the charging port if needed by connecting the new charging port connector to the motherboard.
    • Using a Phillips#0, replace the 2 charging port screws.
    • Reset the right side hinge back into place by pressing down so the hinge is flush against the chromebook base.
    • Secure with the 2 screws using your phillips #0.
  2. Dell Chromebook 3180 Charging Port Replacement, Replace Bottom Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Secure all 7 screws with a Phillips #0
Jon
crwdns2935283:008/18/13crwdne2935283:0
3.945 crwdns2915208:0crwdne2915208:0
crwdns2935297:022crwdne2935297:0
Hey Party Person, nice job. I believe you might be the greatest tech to ever hold a screw driver. This song is for you https://youtu.be/ItWIYcD6jas
foshizol - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 1,189
