Dell Chromebook 3100 non-touch Trackpad Replacement
  1. Dell Chromebook 3100 non-touch Trackpad Replacement, Remove Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 3100 non-touch Trackpad Replacement, Remove Bottom Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 9 screws from the back cover with the Phillips #0 screwdriver. NOTE* You do not need to remove the screws completely as you just need to loosen them enough to remove the cover.
    • Once all 9 screws have been loosened, you can start to pry apart the back cover with your metal or plastic blade. I like to start from the top right hinge area. (See pic)
  2. Dell Chromebook 3100 non-touch Trackpad Replacement, #1 - Remove Battery Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3 battery screws with a Phillips #0 screwdriver.
    • Temporarily disconnect the sticker on the bottom left corner of the battery. You will need to reconnect this sticker when installing the new battery.
    • Lift the battery out of the palm rest. You may feel some resistance while trying to remove the battery. There is a piece of double-sided tape underneath the battery in the top left corner. (See video)
    • Disconnect the motherboard battery cable from the top of the battery.
    • Remove any conductive adhesive tape from the trackpad area.
    • Note* - Keep these small tap strips as you will need to reapply in a later step. This helps block small amounts of static electricity when using the trackpad surface.
    • Move the speaker wire away from the trackpad.
    • Then disconnect the trackpad data cable.
    • Remove the 6 trackpad screws with a Phillips #0 screwdriver
    • Remove the trackpad suspension bracket away from the trackpad.
    • Remove the trackpad from the palmrest.
    • Remove the new trackpad from the package.
    • Remove any protective film from the trackpad surface.
    • Realign the trackpad until it sits flush within the palmrest.
    • Install the second portion of the trackpad which is the small trackpad suspension bracket. This bracket gives the trackpad the "click" gesture.
    • After you have the trackpad and bracket aligned and flush within the palmrest, you can reconnect the trackpad data cable
    • Reroute the speaker cable under the trackpad. You can use the small rubber clips that are preinstalled within the palmrest.
    • Reinstall the 6 trackpad screws with the Phillips #0 screwdriver
    • Reapply all the conductive tape to the trackpad.
    • Note* - you will want to place 1/2 of each piece of tape to the bronze color portions of the trackpad and the other 1/2 to the regular silver color metal. This helps with small static electricity issues when using the trackpad.
Jon
crwdns2935283:008/18/13crwdne2935283:0
3.945 crwdns2915208:0crwdne2915208:0
crwdns2935297:022crwdne2935297:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 1,966
