Dell Chromebook 3100 Motherboard Replacement
  1. Dell Chromebook 3100 Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the laptop so the bottom is facing upwards.
    • Loosen the nine screws from the back panel using a Phillips #0 screwdriver.
  2. Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the back panel away from the rest of the laptop using an iFixit opening tool.
  3. Dell Chromebook 3100 Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 3100 Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws attached to the battery using a Phillips #0 screwdriver.
    • Disconnect the battery from the motherboard by gently pulling on the connector cable at the top of the battery.
  4. Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the battery.
  5. Dell Chromebook 3100 Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully unplug the cord that connects the speakers to the motherboard by gently pulling.
  6. Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your finger or a pry tool, lift the grey switch open from the side closest to you.
    • Remove the EDP cable from its port by gently pulling away from you.
  7. Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your finger or a pry tool to lift up the grey switch of the touch pad cable.
    • Gently remove the ribbon cable by pulling.
  8. Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your finger or a pry tool, gently pull the two dark grey switches toward yourself until they release.
    • Gently remove the keyboard ribbon cable by pulling it.
  9. Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the MB cable by gently pulling.
  10. Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove the 3 mm screw holding down the bracket housing for the EDP cable.
    • Remove the metal plate.
  11. Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the 3mm screw that holds down the metal plate of the wireless adapter
    • Disconnect the two thin antennas connected to the wireless adapter by gently lifting and pulling them up towards you.
  12. Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift open the grey switches of the ribbon cables.
    • Remove the two cables by gently pulling.
  13. Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 3100 Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the four 3mm screws that hold down the motherboard.
    • Remove the motherboard by gently pulling it left and then up to stay clear of the external ports.
Luca Fiore
crwdns2935283:002/25/25crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
University of Kentucky, Team 1-2, Frey Spring 2025 crwdns2935289:0University of Kentucky, Team 1-2, Frey Spring 2025crwdne2935289:0
UKY-FREY-S25S1G2
crwdns2942667:0crwdne2942667:0 189
